Any method for isolating wrist pin noise to a cylinder?
Old Mar 19, 2006 | 01:56 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I just put in a reman engine in a friends ride. It of course is crap like 99% of them! It has a wrist pin making some noise under load at the top of each gear. Is there any method for islolating which cylinder it might be comming from without R&I? I was thinking just pulling 1 plug wire at a time might be the only option since the injectors cant be unpluged.
Old Mar 19, 2006 | 07:24 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Try a stethescope on each cylinder location while it's running - it's amazing what you can hear with one - they have them for cars at HarborFreight and such. A long screwdriver will work too - put the tip on the location, and put the blunt end against your ear - it'll pick up the vibrations.
Old Mar 19, 2006 | 08:44 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Wrist pin noise that I've heard was worse at highest vacuum. Can you hear it all at idle? Is it a dead knock or a rattle sound? I'd suspect something else with the info you've given.
Old Mar 20, 2006 | 08:16 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
It's for sure a wrist pin noise but it isnt noticeable at idle only in gear and 90% of the time at the top of each shift point. I did use the stethescope but nothing too strange at idle or at 2K yet since the engine is still tight for the most part.
Old Mar 20, 2006 | 02:51 PM
Damon's Avatar
If she's rattling at the top of each gear she's not going to last very long regardless. I'd yank it and tear into it before something lets go. Knowing which one is causing the noise does you precious little good if you can't fix it without tearing the motor down anyway. And if it's a wrist pin it should be fairly obvious which one when you take it apart.
Old Mar 23, 2006 | 07:21 PM
ricktaylor's Avatar
Car: 84z28
Engine: 305h.o. mild mod's
Transmission: 700r4 shiftkit
Just rebuilt a 350 for a friend the second time, when he had all the machine work done he didnt bother having new wrist pins put in, had to go into it again and have him have new pins installed, that was a learning experiance for him.
Old Mar 23, 2006 | 10:42 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I actually wanted it to explode so it would have made it easy to find the problem but it hasent let loose yet.
I did get some time to check it out, cyl #7 or to keep this chevy well say #5 is the bad hole. I ended up using a spark tester to kill the hole. I dont know what thier smoking when this particular engine place built this engine but if they want some one to check thier heat tabs they shouldent put them where the motor mounts cover em. I hope the next one is good because that would be 4 engines in a row from this place that were bad, of course not in the same vehical.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
db057
Jan 10, 2020 08:55 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
64Chief
Sep 12, 2015 08:05 AM
