BRODIX 200IK to TPI Base?
Old Mar 20, 2006 | 04:15 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I have the edelbrock high flo TPI Base#3860. I'm interested in the Brodix 220IK heads. I'm just wondering if there heads will mate up with my intake. I looked on Edelbrocks website and they list my intake #3860 as a direct replacement for the stock L98 base. Then the list #3861 for early and aftermarket heads? SO will mine work???
Old Mar 20, 2006 | 10:30 PM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
You really need to do a search about using bigger runner heads on TPI setups. From what I've seen heads with a runner of 220 work better on bigger engines like 383 and 400 sbc. I wouldn't go no higher than a 195 or even a 180 runner I know it will give you a better power curve.
Old Mar 21, 2006 | 12:53 PM
Mark 89Formula's Avatar
The difference between the two Edelbrock part numbers probably reflects the different angle of the center intake manifold bolts on the late model 87-92iron heads (72 degs) versus the factory aluminum and pre-87 iron heads (90 degs). If this turns out to be the case, I've been told you can modify the center bolt holes in the intake to fit either bolt angle. Haven't tried it myself. FYI the Accel base accomodates both angles.
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
Keith5
Aug 27, 2015 04:37 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
Sanjay
Aug 12, 2015 03:41 PM
