torque specifications - Crank pulley bolts
Old Mar 22, 2006 | 06:09 AM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
Does anyone know off the top of their heads? Looking for the proper torque specs for the big crank pulley bolt, and the four smaller bolts that surround it.
Old Mar 22, 2006 | 08:36 AM
Vader's Avatar
Balancer 7/16-20 Hub Bolt: 65-70 ft/lb depending upon year. 70 is usually safe.
The three surrounding balancer sheave 3/8-24 cap screws: 40 ft/lb is adequate.
Old Mar 22, 2006 | 06:43 PM
bobdole369's Avatar
Car: 1989 Firebird
TYVM!!! Needed that
Old Mar 22, 2006 | 11:52 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Balancer 7/16-20
oh! 7/16" FINE! damn, no wonder I was tearing up a coarse 7/16" bolt, while trying to turn the engine in the building stage... hmm, better go find one of those...
Old Mar 23, 2006 | 02:22 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
If you were running a coarse in there I would run a bottoming tap in (7/16 20)and very carefully inspect the threads. dont be suprised it you strip it when yor trying to torque it to 70 ft lbs.
If u have any issues you get to go to 1/2 inch, least its out of the car still :-)
later
Jeremy
Old Mar 23, 2006 | 09:50 AM
Sonix's Avatar
Car: 1982 Trans-Am
yea, i'll tap first and hopefully be ok, only got the coarse bolt in 2 threads...
70ft lbs? what is torqued into that hole anyway? to get the balancer on? or the pulleys?
evilstuie
Jan 9, 2020 08:29 PM
MoJoe
Sep 15, 2015 12:50 AM
Navy8125
Aug 22, 2015 07:13 PM
Street Lethal
Aug 12, 2015 11:33 AM
