need a recipe for 350 TPI
Old Mar 23, 2006 | 04:21 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
okay i have a 350 roller block that i need to build, current specs
accel base/runners
full exhaust/headers
i'm deciding on camshafts i have a crane 2032 but am looking at the lingenfelter 211 which one would work best with the 350?
also whats the deal about forged crank/pistons?
is it bad to use forged rods/pistons with a stock crank?
i have a procharger and will boost it 10lbs and up
also i need to know which heads i can get, i dont have any 350 heads, currently i have wp s/r torquer 305 heads and i dont think i can attain low compression on the 350 for the supercharger
Old Mar 23, 2006 | 11:22 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I have a LPE 74211 cam in my 383 and love it. Not sure how well it would work with a blower.
You'll definately want to go forged on the crank and pistons with a blower.
Splayed main bearing caps would be good too along with studs in place of head bolts.
I'd go with AFR heads if the $ is avaliable.
Old Mar 23, 2006 | 12:17 PM
zorronyellow's Avatar
Car: 89 Pontiac trans am
Engine: 350 5.7 Tpi
call this person he will be the one to talk too about that central time zone 4 to 8 on week days okay. 1-847-244-2235 name is dixon
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
