Modify older intake to fit newer heads ???
Old Mar 23, 2006 | 05:43 PM
greencamaro's Avatar
I would like to run a Perfomer EPS on my 89 heads, but none is available. I guess I don't mind enlarging the center holes on a new new intake, but how do you then get the bolts to hold square on the intake ??
Old Mar 24, 2006 | 05:41 PM
Vader's Avatar
You can either use a spot facer in a mill to machine the deck of the intake at the angle you need, or use 15° structural bolt washers (the kind used to bolt to/through structural I-beams) and file them the few extra degrees to get the angle at a perfect 18°.
Frozer!!!
Jan 19, 2024 04:55 PM
NinjaNife
Aug 23, 2015 11:49 AM
86White_T/A305
Aug 17, 2015 12:16 AM
kyle5647
Aug 15, 2015 11:56 PM
89mulletbird
Aug 12, 2015 07:08 PM
