7000 rpms gave me problems.
Old Apr 4, 2006 | 07:39 AM
  #51
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
you guys are right and I have been wanting to hear what I wanted to hear.
like I stated I am starting to come into reality and I bought a 350 long block that I intend to start building.
the main reason that I am like this is that I spent 4 years on this car and this is the first time I get to drive it and I love it.
I took it on its first road trip during spring break and the rear end blew out on the way up. pinion bearing was howling. on the way back down this happens
You guys might think I am crazy but it was like my car was trying to tell me not to take her on the trip because the MAF sensor was going haywire, the knock sensor broke. one of my exsaust hangers fell off and the emergency brake cable froze up like an hour before I left.
Me bieng hard headed ignored all this and just keep fixing it. luckally the rear end blew up and the pinion nut and the yoke fell off just 10 miles from my buddies house. this made my spring break much more enjoyable as I am sure you can imagine.
I went from a 2.73 to a 3.42 and my car was more fun than ever. So I get it home and this happens.
I am going to put a cam in it and drive it untill it take a #$$% so if you have any tips on how to clean it better of any advise other than take it out before the 350 is done I would greatly appreciate it.
Should I have an engine flush done.
Old Apr 15, 2006 | 08:21 AM
  #52
jamon8's Avatar
Engine: 350 tpi
Its back together and I started it last night!
Old Apr 15, 2006 | 05:47 PM
  #53
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Happy that it runs....just run H/D filters, ones that are capable of holding a lot of crap and filtering really well...oil flow isnt a concern, filtration is......and a magnetic drainplug....and hope for the best. But it'll blow...just give it time. If it doesn't, it'll still never be the same. Do what you can, work with what you got, just don't forget.
Old Apr 15, 2006 | 06:01 PM
  #54
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
While filter shopping ask for the 2 quart filters. They will help catch the trash left in the engine. I know the fram number is #F373 but cant remembers the others off the top of my head.
Old Apr 15, 2006 | 06:24 PM
  #55
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
If your gonna run it till it coughs, I would change the oil twice as often as normal and just put cheap oil and, as said previously, use the large GM filter (cheap brand) to catch as much crap as possible. It will eventually take a dump on you, so my advice would be to not take it on long trips. This way when it does die, your close to home and not miles and miles away, forced into paying someone else huge dollars to get you home. Good luck with her.....
Old Apr 15, 2006 | 07:37 PM
  #56
jamon8's Avatar
Engine: 350 tpi
yeah I kind of wanted to go on a road trip but I think I should concentrate on building a new motor
at the very least I will be able to get her in and out of the garage while I paint my 69 C-10
Old Apr 20, 2006 | 06:53 PM
  #57
jamon8's Avatar
Engine: 350 tpi
the people who said 0 miles were right and I am tearing the motor down now.
the studs came up and its comming out
Old Apr 20, 2006 | 07:25 PM
  #58
Rob Wade's Avatar
Sorry to here that, man. Gittr done.....summer hasn't even started yet so your not missing anything..
Old Apr 20, 2006 | 10:21 PM
  #59
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
yea get some screw in studs and you'll be set for thirdgenfest. shouldn't be more than a hundo in machine work MAX.
pjsparts
Oct 29, 2025 06:39 PM
db057
Apr 28, 2019 07:45 AM
dbrochard
Oct 3, 2015 12:43 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Stroopwafel
Sep 11, 2015 06:38 AM
