lock-up converter
Old Mar 23, 2006 | 11:13 PM
84 H.O>Z28's Avatar
lock-up converter
Does anyone out there know if the lock-up converter kit is needed if all that i did was replace the carb with a Holley and changed distributors to one with a vacuum advance? All that i did was disconnect the harness to the distributor, but even though the computer is still in the fuse panel I didn't know if it would still control the trans. (The trans kickdown is all installed still). I just read in Chevy Highperformance that you could blow up your trans without the lock-up kit but I thought that the computer could still control it> Any info would be apprechiated, Thanks.Patjr97@yahoo.com
Old Mar 24, 2006 | 12:37 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Some method to control converter clutch is required. The ECM requires feedback from the CCC-qjet for it to control lock up.
Without lock up your trans will generate more heat at low rpm cruise (due to converter slippage). This addtional heat will decrease the life of the trans. I'm fairly certain it will not, however, generate enough heat to explode or even ignite. It will probably just die a slow, slipping death.
Old Mar 24, 2006 | 12:51 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
commonly people buy a switch kit, and put a toggle switch somewhere in the car. A kit is nice if you don't know your wiring so good, but otherwise, some wire and your choice of toggle switch would work.
Old Mar 25, 2006 | 06:04 PM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
in the Pic A is purple, B is tan with a black line, and D is light blue.
the switch works great
if some one would wright up a technical article with this info that could help a few people with out the computer controlled stuff.
Old Mar 26, 2006 | 08:27 AM
naf's Avatar
naf
I would recommend running your ground through the existing brake switch ground. Wiring is already there and the brake switch can come in handy at times.
Old Mar 26, 2006 | 10:46 PM
84 H.O>Z28's Avatar
lock-up converter
Thanks for info. it is apprechiated, I did buy the lock-up converter kit from painless wiring but before I either attempted doing it myself or had it done I just wanted to be sure if it was really necessary. Thanks again.
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
