engine tapping
Old Mar 23, 2006 | 11:37 PM
JFROG's Avatar
Car: 84 berlinetta
Transmission: auto
engine tapping
have 91 RS with 305 tbi. notice a tapping sound from engine when temp is at operating temp(about 170-220) oil is not low and oil pressure looks normal. does the usual 60 when cold and 20-50 when at operating temp. fluctuates with rpms ( noted this on several third gens) thinking about trying marvel mystery oil or running a quart of atf in the oil to see if that helps. any other opinions appreciated
Old Mar 23, 2006 | 11:38 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
is the tapping sound coming from the TBI throttle body, i know on my truck the TBI injectors make some noise.
Old Mar 23, 2006 | 11:55 PM
JFROG's Avatar
Car: 84 berlinetta
Transmission: auto
seems to be on the passenger side. not sure to tell exactly where without an auto stethoscope
Old Mar 24, 2006 | 12:07 AM
xpndbl3's Avatar
Car: 1984 Z28
tapping sound could be exhaust leak at the passenger head, loose rocker arms nuts, etc etc. it sounds like the motor is making good oil pressure so i wouldn't sweat it being a bearing noise just yet.
Old Mar 24, 2006 | 12:10 AM
JFROG's Avatar
Car: 84 berlinetta
Transmission: auto
will check gasket on headers if ok will check torqe specs on rockers. see how that goes, thanks
JFROG's Avatar
Car: 84 berlinetta
Transmission: auto
Old Mar 24, 2006 | 09:41 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
transmission fluid- please I have to hear this one
Old Apr 1, 2006 | 11:32 PM
JFROG's Avatar
Car: 84 berlinetta
Transmission: auto
put in new exhaust gaskets on headers and ypipes. sounded no different. so then i removed the valve cover and tightened the rocker nuts about half a turn, i couldn't find the specs to torque them to so i didn't want to put them to tight. now tapping has gone down to a light clicking. how tight are the rocker bolts supposed to be? should the rocker be able to move at all?
Old Apr 2, 2006 | 02:19 PM
jamon8's Avatar
Engine: 350 tpi
there is a tightening sequence not a specific torque spec. some else may type the whole procedure but I will tell you to get the helms manual. chilton and haynes will have some of the same info but they are like buying a v-6 f-body and helms is the firehawk
Old Apr 2, 2006 | 06:19 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
you probably made it worse by turing the nuts Google up "adjusting valves SBC hydraulic roller"
Old Apr 2, 2006 | 10:03 PM
jamon8's Avatar
Engine: 350 tpi
do yourself a favor and put new rocker nuts on when you go to adjust them again.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
86White_T/A305
Aug 17, 2015 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
