need to passs emmissions i have 2 weeks! help
Old Mar 24, 2006 | 10:04 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
alright the emmissions air quality board wont let me extend my test any more...so i have to try to pass. im not runnin an air pump and i have my egr blocked off all i have is a cat.....do you think i have any chance of passing? what can i do to help me pass...my egr is shut off on my prom. im not runnin the headers/slp runners yet like the sig says...
Old Mar 25, 2006 | 12:42 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
it depends on a lot of things.
my dead stock motor passed here with no cats & a non working EGR. the AIR system was in full working order.
i had a good tune on the chip, i used a 5 gas to help get it right for nspection.
without knowing what its doing, there isn't anyway to know if you'll pass the first time or not.
before going in i would pull 2~4 degrees of timing, it will help some on NOx & HC. check for any codes & fix them, make sure the O2 sensor is working good, a 195 T-stat, it probably wouldn't hurt to flush the injectors & a new set of plugs if its been a while sense the last time you did them, change the oil just before you take it in, a clean air filter, make sure the cat is working good, & then hope for the best.
Old Mar 25, 2006 | 07:54 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Is the test IM 240 style on a roller or a sniffer up the tailpipe and a 1200 ropm and 2400 rom hold?
Roller style will require a decent tune and a working cat converter. Pretty much no way around it on these, believe me I have so so tried :-) Keep trying to I will find a way. lol
I'm assuming that u live in Idaho and it is the sniffer variety of test.
If you have any type of remotely close tune and at least a partially functioning cat, you should pass. U can pass them without a cat if you know the specifics of the test. Just simply tune for the area of the test and dont worry about the rest:-)
As always, hotter is better and so are things like fresh gas and oil and anything else ign. or fuel system that might need some maintenance.
later
Jeremy
Old Mar 25, 2006 | 01:04 PM
RedLava's Avatar
Car: 86 z28
i dont know if this will be true for you but my cat was old and worn out. So i just replaced the cat and i passed with flying colors. My car also doesnt have any other emmisions equipment on it.
Old Mar 25, 2006 | 11:29 PM
Car: 92 1500p\u 2wd
i have the sniffer test...and i found a friend at the emmissions station...so i think i can pass easy...thanks guys
Old Mar 26, 2006 | 07:53 AM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Didn't we already go through this? I just did the same thing......no air...no egr...have a cat..... have fresh oil in it, O2 and pcv must be good and set your timing a 0*. Mine failed the idle portion badly. I did all of the above and EVERY part of the test dropped by half! This was with WAAAAAAYYYYY to much piston to wall clearance and wiped out valve seals! The car used 2 quart every oil change. Try it it will work!
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
lewandom
Oct 1, 2015 08:15 AM
