Resleeve no4 cylinder?
Old Mar 27, 2006 | 10:39 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Is it possible with good results on a supercharged engine?
How much oval will cyl.no. 2 and 6 be?
/N.
Old Mar 28, 2006 | 12:12 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
sleeving is fine if done right you shouldn't be able to tell it's even there. they will bore out the surrounding cylinder walls as well if you're rebuilding the motor. I'm guessing in sweden it's tough to locate engine blocks and this is why you're doing this.
Old Mar 28, 2006 | 04:08 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Will not rebore the engine, I want to use existing pistons.
The reason, My Motown block cracked on me after 1250miles......and I cant affort to buy a new one or new pistons
Old Mar 28, 2006 | 08:49 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i'd be calling World Products if i were you and explain the situation...
Old Mar 28, 2006 | 12:11 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
whoever will be doing the sleeving, should be able to measure nearby cylinders for oval etc, and should be able to hone/bore them if needed. you should be ok, worst case is buying 2 new pistons seperately, and two cylinders worth of new rings to fit those.
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
