383 Block Prep
Old Mar 28, 2006 | 10:12 AM
zrated57's Avatar
383 Block Prep
I am planning on building a 383 stroker, but I need pictures of the work that needs to be done to the block for the crank and rods to work correctly. If anyone has pictures of what they did to their 350 block prep for a 383 please post. Thanks.
Old Mar 28, 2006 | 11:46 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
I really don't have any pictures about what I did but I can offer a few points of interest.
Get the rotating assembly you are going to use and mock it all up in the block, don't have to install the rings. Install the cam and timing chain and spin it a few times. The main areas of contact would be:
Connecting rod and the following: cam lobes, oil pan rail, bottom of bores, oil pan, and possibly pistons (not likely though).
Connecting rods with cap screws improves clearance, but you might still have to break out the die grinder and touch up a few spots. I had to knock a little off the rods and around the oil pan rail, but nothing too bad. Also, get the rotating assembly balanced after clearancing is all done.
I might have some pictures at my home computer, I'll check tonight.
Old Mar 28, 2006 | 12:09 PM
zrated57's Avatar
Okay, thanks. E-mail me those pictures if you get time.
PS I have been attacking myself trying to figure out what the comment in your signature means. The Denny's and IHOP one, what's that mean, lol.
Thanks Again,
ERIK
Old Mar 28, 2006 | 02:12 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Heres a 406 but it basically gives you the idea what has to be done to a 383.
Old Mar 28, 2006 | 03:00 PM
zrated57's Avatar
Awesome. I see exactly what needs to be done now. Grinding it doesn't make it any weaker? How much room should I give between the crank and the grinding point. Should there be room for it to move any?
Old Mar 28, 2006 | 03:16 PM
shaggy56's Avatar
Car: 71 Nova
.050" is probably OK but I wouldn't grind much more than .075".
Old Mar 28, 2006 | 04:06 PM
zrated57's Avatar
Should I just tell my machine shop to clearance the block for a 383 for me? How much would that cost? Otherwise I could probably handle that part myself.
Old Mar 28, 2006 | 04:23 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
.060 is the minimum gap
Old Mar 28, 2006 | 04:38 PM
zrated57's Avatar
So 0.050" or 0.075" shouldn't be my guidelines
Old Mar 28, 2006 | 04:40 PM
shaggy56's Avatar
Car: 71 Nova
Every source I see shows .050 as minimum but .060 wont hurt. Just dont go crazy.
Old Mar 28, 2006 | 04:50 PM
Merlin's Avatar
Not really. Interference, however, will make it significantly weaker. Make sure you can drive at least an 0.050" feeler through any areas of concern.
Old Mar 30, 2006 | 07:07 AM
Car: 1986 Iroc
Engine: Afr 408
I used .050" for clearance on everything. You should be fine if you use that. The pictures shaggy posted are way clearer than the ones I have so use those. Also, don't go too crazy with the grinding near the bottom of the cylinders because you can break into a water jacket. You shouldn't have a problem with a 383, but the larger stroker motors typically do.
You could get the shop to do it, but as you know its more $$$. Its kinda up to you. If you have the tools, I would say go for it. Just take your time.
Old Mar 30, 2006 | 07:47 AM
A commonly-used unit of measure for clearance, is a thin tie-wrap.
Old Mar 30, 2006 | 10:12 AM
zrated57's Avatar
Thank you. I think I may have the shop do it if it's not going to be too expensive. I just hope they have clearanced for 383's before.
Old Mar 30, 2006 | 02:06 PM
AC's Avatar
AC
Car: Used to drive a camaro
This was a great post in another section (gets my vote for a sticky!)
Great info / pix of a 350 block prep for a stroker crank.
https://www.thirdgen.org/forums/fabrication/354295-clearancing-stroker-crank.html
UltRoadWarrior9
Apr 28, 2020 10:39 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
