What should it run?
Old Mar 30, 2006 | 03:32 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
What should it run?
Im just trying to get a ballpark idea as to how good this combo is..
This is my setup:
1979 4 bolt main 350 bored 30 thousandths over
Comp cams xe262h-10
Heads that the intake ports have been gasket matched *otherwise bone stock*
Performer rpm intake manifold
Stock q-jet *uses an adapter for the manifold thats a square bore*
Headman headers, dont know what size.
Stock torque converter/rear end
Transmission is a 700r4, but it has a shift kit installed.
So what kind of numbers do you think this should show once I get it all put back together?
Here is a picture of the engine as I have it now, on the stand:
http://img470.imageshack.us/img470/8...06large6eb.jpg
And of my car/garage:
http://img96.imageshack.us/img96/504...04large3bu.jpg
I got the cam in the mail today, im about to place my next order that includes everything to get her running.
Old Mar 30, 2006 | 03:54 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I'd say 9's flat.. but seriously there isn't enough info at all to even make an educated guess... You didn't even so much as say what kinda of stock heads they are..
Old Mar 30, 2006 | 05:25 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
well, now im totally confused...
One head is 3973487x
The other is 3998920
The block/heads are suppose to be off a 79 vette originally.
What other information could I give you to help you give me some idea.
Old Mar 30, 2006 | 05:32 PM
yupitsdadsbird's Avatar
Car: 91 RS
Engine: 5.0 tbi
Originally Posted by 89RsPower!
I'd say 9's flat..
?????? good lord.........I'll probly run a 7 then........well my setup is=====
72 4-bolt block
30 over flat tops
480int 495exh 288 288 cam
roller timin set
full port and polish on a set of old straight plug power pack heads( ya know the ones __/\__
650 holley vac sec, mec choke
port matched edelbrock performer
open element w/ k/n (might get the xtreme flow lip too)
stock dist with msd coil, module, vac advance kit
10.8 wires
1 5/8 equal long tubes w/ 3" collector
30" glasspacks w/ 2 1/2 outlet
th350 stage2 shift kit
tempo converter and rear.....will be changed to a stall to match rear and power band on the motor.....
so now will that be a 7 sec car?
oh and I don't think I'll lose too much trac with the 275/60 s I got on there?
Old Mar 30, 2006 | 05:40 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
Yup he was being sarcastic All I can find on one of your heads is its from a 72-73 350, and the other one I can't find a thing. Maybe you misread some numbers? Either way those heads are gonna hold you back quite a bit. I would guess a mid to high 13. A buddy of mine was running a similiar setup with a little bit larger cam and some home ported double bumps, he ran a 13.3
Old Mar 30, 2006 | 05:57 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
awesome, yeah I plan on ditching these heads and saving up for some good ones. This whole engine build is basically a really low budget project.
Old Mar 30, 2006 | 06:15 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
14.20's.
Old Mar 30, 2006 | 06:29 PM
Car: 91 RS
Engine: 5.0 tbi
all I expect for mine is a mid to high 13
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
Originally Posted by Dialed_In
14.20's.
Old Mar 30, 2006 | 07:20 PM
Dialed_In's Avatar
I wasn't trying to be funny or make fun of you.
Old Mar 30, 2006 | 08:08 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
Ah, I thought you said 14.20 because of the whole 420 thing and all.
I hope it does better than 14, my friends got an eagle talon with 20 lbs of boost that I need to somehow get ahead of.
Old Mar 30, 2006 | 08:14 PM
Dialed_In's Avatar
Nah, I said 14.20's because you didn't mention anythng about the trans, converter, gears or suspension so I assume that it's all stock. Under that assumption low 14's are likely.
Old Mar 30, 2006 | 08:54 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
stock converter
trans is a 700r4 with a shift kit installed
rear end/suspension = bone stock
ill stick with 14's, thats a good number for me at the moment, especially since I plan on putting new heads/carb on it eventually.
Old Mar 31, 2006 | 06:05 AM
Car: 91 RS
Engine: 5.0 tbi
to get past that talon your gonna need to get all you can and he'll probly still take you on take ooff. you need a 3.4? to 4.10 gearing in posi, sub-frame connectors, and at least rear control arms, if junkyard provides a aluminum drive shaft. oh and dump all un-nessasary weight (like a/c which with airbox can add up too 200lbs )
then rewire the majority of the car to aswitch panel where the heat/a/c switches were......looks good too
Old Mar 31, 2006 | 06:22 AM
EvilCartman's Avatar
Car: '82 Z28
200 lbs? I think not. Compressor, condenser, accumulator, lines, box, duct work behind dash and all the rest of the little bits would probably add up to around 70 lbs.
Old Mar 31, 2006 | 01:11 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
Yeah, the talon runs 13.12 in the quarter..soooo I need to start saving up some money.
Future plans for my car are as follows:
New heads
New carb
aluminum driveshaft
and thats about it untill I save up even more money for other things
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
