HEI coil drive capacity
Old Apr 4, 2006 | 06:30 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Guys, how low a coil primary resistance can an 8-pin HEI module drive? I've been looking at the tech data on a number of aftermarket hot external HEI coils, and they all have a primary resistance between 0.3 and 0.5 ohms. I don't want to burn up the module! Any idea what's safe? Thanks!
Old Apr 4, 2006 | 11:23 PM
Vader's Avatar
Impedeance is just as important as resistance in this case. The CEMF from the coil core after saturation limits current flow as much as the resistance.
FWIW, stock coils are supposed to be "good" between 0.1 and 1 ohm primary resistance. Again, that says little about impedance.
92camaroJoe
Jul 29, 2023 07:57 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
midias
Aug 15, 2015 05:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
