which oil pan for a 383?
Old Apr 5, 2006 | 05:04 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i layed my stupid *** oil pan up against the engine today, bolted it up not even thinking about clearance. of coarse it dont clear. what are you guys using for a oil pan on your strokers? my pump and pickup is already setup for a stock depth oil pan which is what i beleive is 7". please someone help me.
Old Apr 5, 2006 | 06:55 AM
Stock with a little massaging around the rails if necessary
Old Apr 5, 2006 | 07:54 AM
Ratchet's Avatar
A stock pan works fine. But as stated You have to massage it a bit. The area we had to massage is the big flat baffle that covers most of the bottom of the pan. To check it just put it on the engine and turn the crank over a couple of times. you will see where it hits. Where ever it hits add clearance. Use the method that works best for you. ie cut and reweld, bash with a hammer etc.
Ric
Old Apr 5, 2006 | 08:43 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I used a massaged stock oil pan as well. I had to replace one of the hex head pan bolts with an allen head since I was no longer to get a socket on a regular bolt head.
Old Apr 5, 2006 | 12:08 PM
Wayne's 383Iroc's Avatar
Car: 88 IROC
Engine: 383
I did the same as ZZ28ZZ and had no issues
Old Apr 5, 2006 | 02:25 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
it looks like the whole counterweight at the front of the engine is scraping along the bottom of the pan. im afraid if i bash it in, i will distort the lip at the front.
Old Apr 5, 2006 | 02:52 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
use a gouge chisel on a 2x4 to create the shape you want in the pan,set the pan on the 2x4,and have at it with a ball peen hammer.go easy and reshape the metal over the area many many times.tap,tap,tap...........etc.my pan is already painted so i will be using a few shop towels between the pan and wood to try to save the paint,if not,oh well,i'll touch it up.remember,if the engine is already cleaned and assembled,wipe the counterweights and pan down after each rotation!
this idea just came to me,but it should work just fine.
i'll be doing mine in a few days if you want to wait for pics.
i've got a spare pan to practice on and will post the results when time and energy permit.
Eric B
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
