Centerbolt to Perimeter Bolt?
Old Apr 6, 2006 | 12:53 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I want to get a set of IK200's from Brodix, but they only come in a perimeter bolt style. I've currently got the centerbolt L98 Stockers. Will the TPI intake still bolt to the heads, or am I going to have to modify it or get new centerbolt heads altogether? Anyone done this before?
Old Apr 6, 2006 | 01:02 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The valve cover bolt pattern has nothing to do with how the intake bolts to the heads. What will matter, though, is the angle of center 2 bolt holes on the intake. However, that too can be fixed by wallowing out the center 2 holes on the intake.
IMO, a new set of valve covers is just fine considering Brodix makes some great heads.
Old Apr 6, 2006 | 01:15 AM
Yeah, I was planning on getting Valve covers anyhow, since mine are all shoddy looking. No better way to top off the looks of the engine bay with a new set of valve covers =).
When you say wallowing out, do you mean just grinding the hole so that it is at an angle so that the bolt will fit through?
Old Apr 6, 2006 | 02:50 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Yea, pretty much. Then you just find some sort of spacer to mate the bolt head to the intake properly to apply adequate clamping force. I've never done it personally, so try searching the boards and see what people are using.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
