Are L98 heads really worth modifying?
Old Apr 5, 2006 | 11:43 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I don't know what they flow or much about them. I did however clean some of them up today.
Old Apr 5, 2006 | 11:50 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Depending on the options of other heads, they take to modifications as well as the 416's and such.
Old Apr 5, 2006 | 11:52 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Could I get 350-400hp from this motor with a decent cam (example: cc305 220/230 .544/.544 112)?
Old Apr 5, 2006 | 11:54 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Yep.
Old Apr 6, 2006 | 12:12 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
very easily, i speak from experience....
Old Apr 6, 2006 | 01:22 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
So if I gasket-match the ports, mill down the bosses and go for screw-in studs, you think that would be enough?
Old Apr 6, 2006 | 02:47 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
DIY port job. Gasket matching won't net you much of anything in comparison.
Old Apr 6, 2006 | 06:12 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
get the heads machined at a shop, have them make the valves sit lower in the seat, that way the first bit of lift seems like more. This also allows them to flow more.
Clean up the chambers, unshroud them a little.
Port out the intake if ya want to, short side radius is alway the biggest concern.
Polish exhaust side!
once all this is done, wala, decent flowing heads for an easy to come by amount.
Frozer!!!
Jan 19, 2024 04:55 PM
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
CRFred
Feb 7, 2016 11:39 PM
NinjaNife
Aug 23, 2015 11:49 AM
