1991 RS wont start right
Old Apr 6, 2006 | 09:54 AM
andrewlinhart's Avatar
Car: 1991 RS
Engine: 350 TBI
I have a 1991 RS with a 350 TBI in it(not original engine of course) The car starts fine when its cold, but after it gets up to operating temp. and you turn it off for a few minutes and when i got back to start it, it starts up and dies after a few seconds. What could be my problem maybe?
Old Apr 6, 2006 | 11:40 PM
Conv389drv's Avatar
Maybe vapor lock from the fuel getting too hot? Check your fuel line routing on your replacement engine and see if it's getting too much heat from somewhere. Rule of thumb for electronics in the engine bay is that you wanna be able to hold your hand on it for a few seconds when everything's at operating temp. If it's too hot to touch, it's too hot! Don't know how it applies to fuel, but probably similar.
Old Apr 10, 2006 | 12:58 AM
Vader's Avatar
Your description sounds like it may be over-rich due to injector leakage, or possibly a weak ignition coil or HEI module that cannot function after heat soak. Does starting when hot become easier/faster if you open the throttle while cranking?
jhawkeye
May 25, 2022 06:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Cripley
Aug 17, 2015 03:35 PM
