can this overflow tank be used as "recirculating"???
Old Apr 7, 2006 | 03:49 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i bought this from summit because my fenderwells are shaved and that ugly bottle isnt going back on there!
problem is summit says this isnt recirculating and i dont understand why.
i will install the coolant intake fitting on the bottom and put the drain petcock at the top. this should then make it recirculate, correct?
the vacuum in the cooling system pulls the coolant back into the radiator when the level drops back down, right?
heres a pic of where its mounted too, it is below the overflow on the rad if it makes a difference.
Old Apr 7, 2006 | 03:51 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
hmmm...
Old Apr 7, 2006 | 06:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'd have to leave the petcock open all the time, but I can't see why it shouldn't work. It doesn't look like it holds all that much though.
Old Apr 7, 2006 | 11:06 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
i figured it should work but i just wanted to get some second opinions.
yea, its not very big but for the look i wanted this was all i could get...hopefully it works out.
Bohemian
Aug 15, 2017 05:11 PM
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
kx3g
Sep 28, 2015 08:14 AM
lanceflame44
Sep 25, 2015 12:28 PM
