pre 86 cam and lifters in a 86 up block
Car: 1989 RS
Transmission: t5
Axle/Gears: 373 locker
I have a 89 305 I was wondering if I could scrap the roller cam and lifters and run a pre 86 hydraulic flat tappet cam and lifters? Could I keep my pushrods? I would like to run one of those comp cams nitrous hp cams. I would keep the roller stuff but im shure the roller lifters a worn and I dont like any of the replacment cams.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I *believe* you can just pop it right in, not 100% sure though. I know for sure that the pushrods will be a different length from roller to flat tapett though
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
yep, you're good. but for the price of buying all these new parts, or just buying the cam and having the benefits of a roller cam.....? (unless you have alterior motives.)
also, the newest (or maybe 2nd newest) super chevy or car craft did an independant test on nitrous cams. Didn't do anything (actually worse results). Never seen that kind of test in a magazine (one that DIDN'T promote a product), but it's worth thinking about.
ambainb
Apr 25, 2016 09:21 PM
MoJoe
Sep 24, 2015 09:12 PM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
