Dies when hot 85 Camaro 2.8
Old Apr 7, 2006 | 10:28 PM
89IrocZRagtop's Avatar
Car: 89 Iroc Z Convert, 89 RS Convert
Engine: 305 TPI, 305 TBI
Transmission: 5 Speed,
I have an 85 Camaro 2.8 MPFI 5 speed. Runs great all winter long with no problems at all. Summer comes and Temps out side start getting up around 90 degrees and the car just dies & will not start until the engine cools down. It is not overheating. I am getting no codes. Replaced coil and control module, neither one helped. Summer is coming and would like this fixed before the temps start riseing. This has been going on for 3 summers now. Only happens on really hot days. I live in Minnesota so we don't get that many really hot days. Please Help with any suggestions.
P.S. Also looking for a Steering Column for my 89 Iroc Convertible
Old Apr 17, 2006 | 12:54 PM
LetsRock's Avatar
Car: 1989 Trans Am GTA
Engine: LB9 TPI with L98 cam (Manual car)
Transmission: T5 5Speed/ 9bolt Borg-Warner 3.45 gears with posi
Replace your ignition parts. Coil, hall effect pickup, rotor, etc. This is more than likely an ignition issue..
pimp2303
Jul 27, 2017 02:03 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
86Base
Aug 8, 2015 01:34 PM
