zz4 cam in L03
Old Apr 8, 2006 | 09:22 PM
pyro719juggalo's Avatar
Car: 1989 RS
Transmission: t5
Axle/Gears: 373 locker
zz4 cam in L03
can I run a zz4 cam in my LO3 with out changing valve springs? If not what is the biggest cam I can run? How bout a lt4 hot cam? Let me know thanks guys. Oh and i in the process of switching from tbi to carb so computer is not an issue.
Old Apr 8, 2006 | 10:26 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Why are springs such a big issue? If youre going to go to the trouble of putting a new cam in, i dont get why you wouldnt just spend the money on some descent springs. Theyre not that expensive, its lifters and rockers that get expensive
Old Apr 9, 2006 | 10:24 AM
Car: 1989 RS
Transmission: t5
so I would need to upgrade the springs? Can anyone recomend a good cheap replacment spring for this cam? Thanks
Old Apr 9, 2006 | 12:11 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I think the factory LT1 springs would be a decent cheap set. May have to open up the spring pockets though.
comp 981's are a direct drop in, maybe a bit more cash though.
Old Apr 10, 2006 | 11:49 AM
Car: 1989 RS
Transmission: t5
would the zz4 cam work well in an lo3? what kind of power can I expect. It is bone stock tbi now. Im switching to a carb and hei with a performer intake and heddman long tubes. Also was wondering what the best carb would be cfm wise im thinking a BG 650 or holley dp. Im going to go to a 350 later on so would a 750 dp be to much for the 305?
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Magman
Sep 13, 2015 12:14 AM
Strick1
Sep 4, 2015 07:11 AM
