Plug Gap and Which Carb
Old Apr 10, 2006 | 12:50 PM
Iroc Adio's Avatar
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
I have 11.5:1 compression and a MSD pro billet distributor with 6al box. What should i gap my plugs at. Also I have an automatic trans and Ive heard that a vacuum Sec. carb is better then a DP for auto. What do you think? I have a Holley 650 DP with a proform center section and a Holley 750 with vacuum sec. just curious on which would be better for my application
Old Apr 10, 2006 | 12:54 PM
Damon's Avatar
That's a lot of compression. I'd start around .035" (always a good starting point) and then maybe try to go up a little from there. .045 max, I would think to keep from chewing up ignition parts on a regular basis.
Old Apr 10, 2006 | 01:42 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I have a similar setup and I gap my plugs at .040...so somewhere around .035-.040 is a good starting point. I would definately not recommend a vac. secondary carb for your combination, go with a mech. secondary dp carb you won't be disappointed.
Old Apr 10, 2006 | 01:46 PM
Iroc Adio's Avatar
Car: 1987 IROC
I was going to gap them at 45 and use the DP, but i called summit tech line to see what they suggested. They told me to gap the plugs at 55 and use a Vac. Sec. carb. I wasnt sure if that would be right so i posted up on here.
Old Apr 10, 2006 | 01:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
just curious, are you SURE about that compression ratio? like what heads are on it? I'd think you'd need dome pistons and teeny heads for that.
I think .055" gap and vacuum secondary is a very bad idea for you.
Might want to use iridium plugs after you've got the car dialed in
Old Apr 10, 2006 | 02:21 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Normally double pumpers for automatics are not recommended, due to throttle issues at low rpms. Since you have an aftermarket stall (Jegs 3200-3600 stall). I do not see any problem with it. I plan on running a 750 DP on my new 383.
Infested
May 22, 2018 11:56 PM
Jae992
Aug 27, 2015 09:07 AM
Dialed_In
Aug 20, 2015 01:45 PM
GVMV
Aug 16, 2015 08:01 PM
cstrobel65
Aug 15, 2015 10:19 AM
