OEM starters are heavy! Ministarter?
Old Apr 10, 2006 | 02:47 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
For a flywheel of a 87 GTA, what starters are available that don't weigh 25 pounds like the stocker? That damn thing is heavy.
Old Apr 10, 2006 | 03:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Powermaster starters. You can buy real cheap "made in asia" starters but they don't last very long.
JEGS High Performance - Powermaster XS Torque Starters
Old Apr 10, 2006 | 03:25 PM
They're all "made in Asia".
The Powermaster is a Hitachi starter.
The only thing the mini-starter people do is take a OEM starter, and just bolt it to a slab of aluminum that then bolts to a Chevy block. They don't "make" the starter itself.
Most of the aftermarket mini-starters are made from the Hitachi motor.
The other ones are made from a Nippondenso motor. Also "made in Asia"..... or at least by a company of Asian origin, wherever the plant might be.
When you look at them, the ones that have one squarish sort of part, that's the ND motor. The one with all round parts, that's the Hitachi.
Old Apr 10, 2006 | 04:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I didn't dispute that. I just said that the cheap ones don't last long.
The Powermaster starters are about the same size as a Proform starter but will last a lot longer.
There's more "made in asia" parts on a Harley than there is on a Gold Wing.
Old Apr 10, 2006 | 10:26 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
same company that made some parts for my rx7.
kind of interesting
Old Apr 14, 2006 | 12:38 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Go to your nearest parts house and get a reman starter for an '89-91 Corvette with the L98. I believe that one is a Hitachi, bolts right up, and if you get the right brand - has a lifetime warranty!!
3rd gen money
Oct 11, 2019 09:57 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
