ZZX Cam owners inside!
Old Apr 11, 2006 | 06:18 AM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
I just bought one and am looking to put it in soon. I was wondering if any of you guys with the zzx cam have any type of vacuum problems? How is the driveability with this cam? TIA
Old Apr 11, 2006 | 10:46 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Depends on your compression. I wouldn't run anything less than 11:1, 11:5 is better.
My 10.5:1 383 couldn't make enough vaccum with 242-254 110lsa, but the zzx has less overlap. A bud used to have the zzx in a 11.5:1 383 and it ran fine after tuning.
Old Apr 11, 2006 | 11:27 AM
Car: 89 formula 350
11:5? LOL my engine is 10.5:1
Old Apr 12, 2006 | 01:03 AM
Car: 89 formula 350
bump
Old Apr 12, 2006 | 01:07 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Run a vac pump if you dont have adequite vacuume!
Or change out that cam to something more suited to your compression ratio...
Old Apr 12, 2006 | 06:17 AM
Car: 89 formula 350
thanks for the info. I havent installed it yet, and im looking for tips from people that have this cam in their car.
Old Apr 12, 2006 | 01:19 PM
11SEC91Z's Avatar
Car: 91 Z/28
Engine: 6.3 L98
Transmission: TH350 4500 STALL
Axle/Gears: 3.73s
Maybe i can help
You wont have any vacuum problems with this cam.I had stock brakes with no problems.Drivability is just fine,I suggest a Vigilante,Yank,ACT 3200-4000 stall to make the most of the ZZX.Although you could get away with a tad less converter.If you have a T-5 or t-56 you will be good to go.This cam pulls hard from 3500 to 6800.Sounds nice too You will enjoy it!
deracer
Apr 11, 2016 12:04 AM
g.l.mos
Aug 22, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
mustangman65_79
Aug 11, 2015 03:17 PM
