egr block off
Old Apr 11, 2006 | 04:44 PM
ajl'86T/A's Avatar
Car: 1986 T/A
Engine: 5.0 carb
Transmission: 700-R
egr block off
whats the best way to block off the egr valve on an LG4?
Old Apr 11, 2006 | 07:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Unplug the vacuum hose.
Exactly why are you wanting to do this?
Old Apr 11, 2006 | 07:44 PM
ajl'86T/A's Avatar
Car: 1986 T/A
Engine: 5.0 carb
Transmission: 700-R
because i thinks its worn out. all i know is that with the intake hole plugged where the egr used to be, the car idles smoother and doesnt miss as much, im pretty sure the reason why it misses at all is due to a vacuum leak on the manifold that i just found today (after i posted this), but anyways ive heard that doing this will give you a little exra power (prolly no noticeable i kno), but theres no point in replacing it is there?
Old Apr 11, 2006 | 08:09 PM
five7kid's Avatar
Yes, there is. The ignition timing curve assumes the valve is operating. Without the valve, you'll get part-throttle pinging with otherwise proper timing and proper octane fuel.
If it's a vacuum leak on the manifold, is it possible it's just the valve gasket that's leaking?
Old Apr 11, 2006 | 08:22 PM
ajl'86T/A's Avatar
Car: 1986 T/A
Engine: 5.0 carb
Transmission: 700-R
ya im pretty sure that fixing that leak should clear up the problem now taht i found it. but theres no way to take the egr off w/o running high octane fuel or what? cuz ive heard of people taking it off and i really dont want to replace it unless i have to
Old Apr 11, 2006 | 11:19 PM
five7kid's Avatar
Back off the timing and take the hit in economy and power.
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
