Don't beat on me light under WOT
Old Apr 14, 2006 | 01:04 PM
Twowheelpeel's Avatar
Car: 1992 Pontiac Trans AM GTA
Engine: L98 350
I've got a '92 GTA with L98 in it, mostly stock with 51,000 miles. I can press the gas down up to say 90% or just about to the floor and the car gets up and goes no problem. But, if I floor it the check engine light will come on, then when I take my foot off the gas and wait about 5 seconds or so the light turns off. Under full throttle the car accelerates quickly and runs fine with the exception of the light coming on.
Any ideas what it could be?? To add, my car has lead a pretty good life, it hasn't ever seen snow/salt and It has been driven in the rain a few times. The first time I noticed this problem, I was out on a nice saturday ride on a clear day. With my luck as I was driving I went into a huge downpour for like 15minutes. I've have the check engine light problem ever since, maybe a sensor shorted out?? I also don't drive like a maniac all the time so its hard to tell if I've had the problem for a longer time and just didn't notice.
The car hasn't set a code, and thats probably because the check engine light doesn't stay on. But, that also doesn't make me feel any better if I am doing damage to it now. Any ideas?? Thanks.
Old Apr 14, 2006 | 02:05 PM
88 IROC CONVERT's Avatar
Car: 2002 zr2 Blazer 88 Iroc convertable
Engine: 305 T.P.I.
tps
check tps from idle to full throttle with engine off. use ohm meter it should have a smooth reading. then with key in on position take volt reading with engine off. it may be it doesnt see wot good luck
Old Apr 14, 2006 | 03:10 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Check for codes.
Old Apr 14, 2006 | 04:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If the light comes on, a code has been set.
Unless the ECM is at fault. Not likely.
Jae992
Aug 27, 2015 09:07 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Omega
Aug 10, 2015 12:46 PM
