Timing for mild 305
Old Apr 14, 2006 | 05:58 PM
Demon355's Avatar
Timing for mild 305
'87 GTA LB9/Auto/3.23 Posi
Ported 081 heads - bowl/valve cut/ports
Stock internals
LT1 cam (might use L98 also)
1.6 Pro magnum rockers
22lbs injectors
Ported plenum, base and runners (might get slp runners)
CAI/Air Foil
Holley AFPR
Full exhaust
Full accel ignition
What should I bump the timing too? I've searched a few threads but haven't got a complete answer so I figured I'd throw my combo out there and see what you guys think. You're thoughts?
Old Apr 14, 2006 | 06:37 PM
joe350's Avatar
Car: 91 Z28
Engine: 350 TPI (L98)
Don't be ghetto. Get your timing tuned on the dyno. If you insist on advancing it yourself though, 10-12 degrees BTDC usually seems to work.
Old Apr 14, 2006 | 06:53 PM
Demon355's Avatar
That's all I really needed was a starting point, thanks
Jake_92RS
Jan 28, 2020 10:37 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
justin57
Aug 20, 2015 07:05 PM
st.evel07
Aug 13, 2015 06:15 PM
