THE FORMULA KEEPS DYING!!!!! HELP PLEASE!!!
Old Apr 15, 2006 | 03:54 AM
RED5SPDFORM's Avatar
Car: 1989 Pontiac Formula
Engine: 305 tpi
Tonight I was driving home with my friends in my car and the damn thing keeps shutting down on me. I get her up to 20 mph then dead she goes try to pop the clutch but I dont get any thing. I have to restart her and try to get her home. I dont know what it can be? The car only has 20000 miles on it now and is all original. Im thinking it could etheir be the plugs and wires because like I said every thing is stock. or it could be the fuel filter or possibly the catalytic converter! I dont know what to do so if you guys can help me itd be great thanks
Old Apr 15, 2006 | 06:18 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Does it restart just fine right away? If it doesn't and you have to wait a bit before it will start up, it might be your ignition module... They can cut out like that when they go bad. If its not that, it might be something simple like your idle air control motor--try cleaning out the passages in the throttle body if they're carboned up...
Old Apr 15, 2006 | 11:19 AM
Engine: 305 tpi
it restarts fine but the car will only run for a few moments then it will shut down and then I have to restart it drive half a block then it just dies. Is this a commom problem with tuned ports??
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
rubblerubble
Mar 13, 2016 06:57 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
Linson
Oct 1, 2015 05:33 PM
90formulaVortec
Sep 8, 2015 12:42 AM
