87 Camaro cutting out/dying when first started
Old Apr 15, 2006 | 03:20 PM
jjg's Avatar
jjg
Hey guys I have an 87 Camaro Iroc z-28 with a 305 TPI, I have recently replaced the 02 sensor, the egr valve, plugs wires rotor an distributor cap and vacuum hoses.. Seems when I first start it up it wants to cut out and die so I hold the gas down until it warms up enough to idle on its own. I put the car in gear RPM's drop to 750. When in park i try to stomp on the gas and it hesitates and cuts out. When i am driving it really seems to bog down and doesn't have any power. Is this a timing issue? If you guys could point me in the right direction I would appreciate it
thanks
John
Old Apr 16, 2006 | 12:35 AM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Have you checked for any codes from the computer?? Could also be a bad fuel pump or clogged fuel filter!!
Old Apr 16, 2006 | 09:25 AM
jjg's Avatar
jjg
Thanks for the response
I have changed the pump a while back probably a few years ago, but I have only put a couple 1,000 miles on it. when I changed the pump I did change the fuel filter. There are no codes, but it doesn't to want to idle when it is cold, I did notice a little backfiring when i stepped on the gas yesterday??
thanks
John
Old Apr 16, 2006 | 02:33 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Check for vacuum leaks around your runners and intake.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Caspar
Jun 19, 2016 11:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
