Pushrod Corrosion
Old Apr 15, 2006 | 04:12 PM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
Pushrod Corrosion
Well, I took out a pushrod or two today because I though one might be bent. Turns out they aren't, but when I was looking at them, at least a couple of them had some surface rust/pitting/corrosion. Is this bad? What is this a sign of? What should I do?
Old Apr 15, 2006 | 07:13 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you got moisture/water into your motor... I'm guessing intake manifold gasket failure?
They're cheap enough to replace. How bad are they? If a stock motor with stock valve springs, then it'd probably take a fair bit of corrosion before they're weak enough to fail.
Old Apr 15, 2006 | 07:29 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Could also be a sign of a faulty PCV system.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Elephantismo
Feb 13, 2019 12:51 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mfp189
Sep 27, 2015 09:25 AM
sahlomonic
Sep 20, 2015 07:15 PM
