doing intake gaskets, few questions - pics
Old Apr 15, 2006 | 07:19 PM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
this is my 87' SC, 169,000k on it, LG4
what exactly is the function of this block off plate, it fell into the lifter valley when i pulled the intake off, it apaears that its supposed to block off the right rear coolant passage
and this line that branches off my one heater hose and goes to the back of the intake. i have had nothing but problems with this thing, first the fitting on the intake broke off and i retaped the hole and put a NPT fitting in there to make it work, but now the hose leaks, and i'm just sick of it. can i just replace the heater hose to the waterpump and block off the intake fitting?
Old Apr 15, 2006 | 07:27 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The first picture is just that, block off plates. If you look at the heads, there are coolant passages cast at the rear. However, provisions are not cast into the intake, so block off plates are used.
The second is probably the return line for the heater control valve. Judging by the picture, try running a longer length of hose and a few hose clamps on the hard line side. Not 100% sure on the setup, though.
Old Apr 16, 2006 | 09:10 AM
White93z34's Avatar
Engine: LB9
the heater control valve is on the other heater hose, this one all it does is go from the firewall to the waterpump, and branches off at the back of the intake.
can i just blockoff the hole on the intake and run a new piece of heater hose from the firewall to waterpump?
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 23, 2015 12:52 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
