Is this close??
Old Apr 18, 2006 | 03:28 PM
new67rs's Avatar
Is this close??
I found this cam. .435/.462 lift- 198/210 @.050
Texas Performance Products Online Store
Is that close to the stock GM cam #10066049 with .415/.430 lift- 207/213
I don't know anything about cam numbers.
These are both rollers.
I'm looking for a cam as close to stock as possible. I'm going for fuel economy.
The current cam is way too large.
Thanks for the help.
-Luke-
Old Apr 18, 2006 | 03:43 PM
Try this instead.
eBay Motors: 96 Corvette C4 LT1 5.7L CAMSHAFT ROLLER LIFTERS ROCKERS (item 8056725586 end time Apr-19-06 18:34:00 PDT)
Throw away all the stuff you don't need.
Old Apr 19, 2006 | 05:38 AM
new67rs's Avatar
Do any of those cam marking mean anything to you. Is this cam close to the ones used in 89 TPI's. Would a 96 LT! cam fit?
Old Apr 19, 2006 | 12:35 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Yes an LT1 cam will fit and give a slight boost in power. Do a to find out tons of info about doing it. It might even get the same or better gas mileage because of the more efficient cam lobe design.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
