Engine Break In Oil!?!?
Old Apr 15, 2006 | 12:17 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i hate this new search...i cant get it to earch engine AND oil etc it will search for one or the opther or both and give me 6478329085 replies...
BUT ive heard around here to run a straight 30wt Non-detergent oil for the first startup...the general concensus around bobistheoilguy's forums is to run a normal oil and a nondetergent is not needed?
can anyone explain some of this to me?
Old Apr 15, 2006 | 04:28 PM
ede's Avatar
ede
i think you'll have a hard time finding a non detergent oil. i use 30w dino oil with gm additive in it and i forget the exact name of the gm stuff. 30 minutes on that and a change to fresh 30w dino oil for another 500 miles then a change to a multi weight oil.
Old Apr 15, 2006 | 07:11 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
GM EOS - Engine oil supplement.
Old Apr 15, 2006 | 07:18 PM
ede's Avatar
ede
yep that's it, talk about brain fade. i sat here thinking for what seemed like forever and finially gave up trying to come up with the name.
Old Apr 15, 2006 | 09:38 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
ok, i thought the GM EOS was a type of oil. Ede thats what i plan to do with the oil changes. i asuume this EOS can be found at the dealer?
also, im unsure what oil filter to get. does anyone wanna recommend one. id like one bigger than the puny one that came stock. AC Delco??
Old Apr 15, 2006 | 09:43 PM
Sonix's Avatar
Car: 1982 Trans-Am
yep dealer, or I got mine from my machine shop, he has it by the crate.
you shouldn't need it every oil change, unless it's a pretty beat up motor...
chevy boi's Avatar
Car: 1989 i roc-z28
Engine: 350 tpi l98
i kno the ph-5 from fram works on my l98 so it should work with yours but dont know what part number it is for ac delco
Old Apr 15, 2006 | 09:50 PM
Dracul's Avatar
Car: 1983 Camaro z28
Engine: 5.7
Transmission: 5spd
if you need non-detergent 30 weight just go to advance auto we stock it and since not too many people buy it there is always some on the shelf...
Old Apr 15, 2006 | 10:21 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Yeah, our shelf has been packed (a full row of it) for as long as I can remember.. heh...
Old Apr 16, 2006 | 01:20 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
well after a lot of searching and talking on bobistheoilguy.com's forums im going with a normal straight 30wt. using, of course, the GM EOS as well.
ill always stay away from Fram oil filters...junk IMO after what ive read about them.
Old Apr 16, 2006 | 01:38 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
At the 600 mile oil change, Mobil 5/30 synthectic and a mobil filter for me.
Old Apr 16, 2006 | 08:45 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
anyone have a part no. for a larger than stock mobil 1 filter?
Old Apr 16, 2006 | 02:39 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
PF-35 by AC Delco will work in place of PF-25.
Old Apr 19, 2006 | 10:06 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
TTT for other oil filter recommendations?
Old Apr 19, 2006 | 10:23 AM
The PF-35 has long since been discontinued.
The one to use now, is the PF-1218.
IIRC the Mobil1 oil fliter of the same size is the M302; but I could easily be wrong about that. Go look up the one for a Chevy truck with a 454.
I'd recommend NOT using non-detergent motor oil. That little bit of hot-rodding folklore has been obsolete for at least 40 years now. Instead, I'd suggest Shell Rotella T oil, since it has lots of the zinc additive that's been disappearing from oil made for cars. The GM EOS is a good idea too.
Old Apr 19, 2006 | 10:27 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
You're not the first person to mention Shell Rotella T oil to me. Good for the break in, or for regular use or both??
Would a big block filter fit (diameter and thread size) on smallblocks?
Old Apr 19, 2006 | 10:32 AM
It's OK oil for regular use, but synthetic would be better.
If your motor has a roller cam, you can use synthetic oil from the start. No need for special break-in oil. People will tell you a bunch of stuff about the rings; that's not true. The ONLY thing you need special break-in oil for in a modern engine, is a flat-tappet cam. Modern rings need no special treatment of the oil in order to break in properly.
Yes the BBC has the same size everything about the oil filter as the SBC.
Old Apr 19, 2006 | 12:54 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I run Shell Rotella in mY 383, the GF's 355 and both 350's in my boat. No problems whatso ever. I would advise NOT to use GM's FP1218 as it is a cheaply made filter now. Its not built the way they used to be. Theres posts about this change online somewhere. I would suggest a Wix, Mobil, Bosch, Napa or even a K&N Filter.
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
