siamesing runners.. tools?
Old Apr 19, 2006 | 11:23 PM
president89's Avatar
Car: 86 Monte carlo ss
Engine: tpi l98
I was reading the article on siamesing the tpi setups. Good write up by the way, but it just references carbide cutting tips. I did a search on these, and there like 20 different styles. Does anyone have a recommendation on which one I use? Post a pic if you can. Or a link to where i can get it online.
Old Apr 20, 2006 | 02:24 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I used sanding drums when I did mine.
Old Apr 20, 2006 | 04:22 PM
Engine: tpi l98
didn't that take a very long time. The thread says carbide bits. i know those cut through metal pretty decent.
Old Apr 20, 2006 | 04:27 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
I think the reason lots of DIY guys try not to use carbide bits is because they are very aggressive and you could really mess something up if you slip just a little.
I may try this method for porting a tpi intake.
-Ported 89 TPI base, just about done (pics) - Corvette Forum
Old Apr 20, 2006 | 09:05 PM
Car: 1989 GTA
Engine: 369 TPI
I have a die grinder with carbide bits. I found I could do a better job with a set of sanding drums. It went faster than you would think and I had better control.
Old Aug 20, 2006 | 03:33 PM
shaggy56's Avatar
Car: 71 Nova
They have aluminum oxide grinding stones that cut through cast iron pretty well and its easier to control. I was able to grind a port within an hour with this method and it came out very smooth.
92projectcamaro
Dec 8, 2015 12:25 AM
Reid Fleming
Oct 10, 2015 09:56 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
mrdevontay
Sep 2, 2015 08:04 PM
