Dancing Oil Pressure gauge - I'm Nervous!
Old Apr 20, 2006 | 06:17 PM
MOMsRide's Avatar
Car: 91 RS Convertible
Engine: 305 TBI
My 91 RS has 116000 miles on it. Until recently my oil pressure gauge has been pretty steady between 45 and 60(ish) psi. Lately though it has been very erratic. When hot, at idle, pressure drops to 30psi; yet when the engine is under load, pressure levels out at 55(ish)psi after an initial jump to well beyond 60 psi.
I have read some of the other posts about drops in oil pressure (0 psi) and am very concerned.
Could it be the oil pump? the valves? the bearings? the gauge? sending unit?How & what exactly can I do to diagnos it's problem? I have checked and I see no metal particles in the oil.
Really don't want to trash the motor... would prefer to fix problem now!
Old Apr 20, 2006 | 10:43 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
dont worry too bad man..if the cars not smoking or pinging or knocking or overheating have no fear.......mine is doing the same thing and it still runs like a top....check the connection to the sending unit (the sending unit is above your oil filter screwed into the oil filter adapter) if the connections look fine its probably just the sending unit....thats where i would start with a new one.....I am fixing to do an engine swap so im not too worried about mine at this time cause when i swap i'll be using all new parts anyway.....but try that first and let me know.....hope this helps
Old Apr 21, 2006 | 01:14 AM
iroc22's Avatar
GM oil pressure sending units are very commonly found to fail or act erractically.
Old Apr 21, 2006 | 06:00 AM
irocz28gal's Avatar
oil pressure
I know this all too well. I have an 85 Iroc with 26,500 miles on it (original), did the same thing, and they just replaced the "sending unit" for me. Works fine now.
Old Apr 21, 2006 | 07:41 AM
MOMsRide's Avatar
Engine: 305 TBI
OK, first step-sending unit
I will replace sending unit this weekend as a first step. Autozone stocks 'em for $28. Sounds like a good place to start. Thanks for the help guys!
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
