when should the dizzy point @ #1?
Old Apr 22, 2006 | 12:08 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
finding TDC, stupid question im sure, but anyways, with the valve cover off on #1, should the dizzy be stabbed when the intake valve closes? or right before the exhaust valve opens? or in between? thanks
Old Apr 22, 2006 | 12:15 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Umm... I typically start corner to corner with the piston at TDC so I'm close, I don't go by the valves for anything but figuring which stroke I'm on. :shrug: I'm sure there are going to be a slew of methods mentioned.
Old Apr 22, 2006 | 12:19 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
what do you mean by this "corner to corner"?
Old Apr 22, 2006 | 12:32 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
When you look at it I have the leading corner of the rotor just into the facing corner of the post.
rotor ---------
------- post
If that comes out it'll be a really crappy visual, but should make more sense than me trying to explain it.
Old Apr 22, 2006 | 12:47 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
You,ll be close if you go by the intake valve closing, which is all you need until the engine starts up then you can set the timing to specifications. If the piston is at compression stroke TDC the dizzy rotor should be just about to break contact with the post.
Old Apr 22, 2006 | 12:48 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
sweet i think i got it.
the exhaust valve opens up when the piston is near the bottom of the power stroke, correct?
Old Apr 22, 2006 | 01:28 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
yes, the piston is then shot back up, expending the used gases through the valve.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
school boy
Oct 22, 2015 11:47 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
