Cam and Lifters
Old Apr 23, 2006 | 12:42 PM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Cam and Lifters
Okay, I have a really dumb question. I am builiding a 350 engine out of an 88GTA. I have a speed density TPI set-up with high flow runners and a high flow intake. My question is about the cam and lifters that I should use. More specifically I would like to know what type; roller, hydraulic, flat-tappet. I really do not understand the differences between the different types of cams/lifter.
Thank you for everyones help!
Old Apr 23, 2006 | 12:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Your 88 engine will have factory hydraulic rollers. You can reuse your lifters as long as they're in good shape, and you need a cam for a factory roller block.
Old Apr 23, 2006 | 12:57 PM
wildjyoung's Avatar
Cam and Lifters
Okay, so I need to purchase a roller cam and hydraulic lifters? Any suggestions on brand? Currently, I am building a 383 stroker and I am not sure about heads yet. I would hate to put the stock heads on there but I cannot find anything for my budget ($1000).
Old Apr 23, 2006 | 01:21 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, just a roller cam for a factory roller block. You already have the lifters.
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Stryker412
Sep 7, 2015 09:11 AM
dimented24x7
Sep 6, 2015 03:51 PM
z28guy134
Sep 1, 2015 11:50 PM
