flywheel recommendations
Old Apr 23, 2006 | 03:08 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
SETUP:
350 1 piece rear main seal
probably about 400hp at the engine
I'm running a t5 for now, stock clutch. -Plans for t56 in the future.
GM bowtie high tq mini starter
externally balanced engine (I think, keep reading)
I'm looking for a steel flywheel. This is not a dragcar so this rules out aluminum. Stop lights would be a killer.. So, any recommendations? My stock flywheel which came with the origional 92 305 TBI engine (I swapped it over) is missing a lot of teeth. I also need to know how many teeth the stock 1992 305 TBI flywheel had.
My next question is how would I balance it? Being that I have the scoogin dickey tpi engine and it's externally balanced.... This I am pretty sure of though I may be wrong. Correct me if I am. Any help would be appreciated a long way.
I'm also seeing a lot of these warning on new flywheels:
Performance and SFI-approved flywheels must be used with performance clutch discs only. Use of a stock-style clutch disk with a performance flywheel will often result in insufficient operating clearance between the disc hub and flywheel bolts.
Old Apr 25, 2006 | 10:58 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
Your factory flywheel had 153 teeth.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
