Does my 1987 Z-28 5.0f
Old Apr 26, 2006 | 05:51 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Have self-aligning rockers? Everything I read says 88-newer, but I do have the hydraulic-roller f motor.....
Old Apr 26, 2006 | 06:58 PM
'Shifter's Avatar
Car: 87 Z-28
Second part of the question....can I use self-aligning rockers on a non self aligning head if needed?
Old Apr 27, 2006 | 10:14 AM
'Shifter's Avatar
Car: 87 Z-28
BTT
Old Apr 27, 2006 | 10:20 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
1st question: Yes you do have self aligning Rockers, second question: Yes you can use self aligners on non self aligned heads. If you want to make sure, take one of the valve covers off and look for guide plates, or pull off one of the rockers and see if it has an indention where it contacts the valve (like a little recession the valve stem sits in).
Old Apr 27, 2006 | 01:18 PM
'Shifter's Avatar
Car: 87 Z-28
Hmmmm....o.k.....what if I'm talking roller rockers...if the valve stem tip isn't high enough above the retainers,
won't the rails on the rocker tip roll on the retainers instead of the valve stem?
ZEEYAA
Apr 16, 2023 08:29 PM
David Frans
Oct 31, 2015 08:12 PM
lewandom
Oct 1, 2015 08:15 AM
bplessy
Sep 30, 2015 12:14 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
