Wont Restart when hott
Old Apr 27, 2006 | 07:36 PM
havoxe30's Avatar
Car: 88 GTA
Engine: l98 Modded
Transmission: 700r4 Built
Hey, i have been having the same issue since i have owned my GTA. When it gets hott it wont restart , it only happens when its hott outside not in the winter or the mornings. It will run fine when im driving but asoon as i shut it off it wont restart for like 2 hours untill it cools down all the way. Some times it will act like it is going to start but will then die, i can keep it running alittle if i, WOT and let off and keep doing that it will try to idle but will backfire and then die. I checked spark i took the coil wire off the dizzy and its still sparks and im still getting fuel, but the gas is really hott i dont know if that has anythign to do with it but its kinda abnormal hott. it has new dizzy,wires,plugs,and spark control module the only thing i havent done yet is the coil. So can anyone help me out , im tired off waiting hours to leave somewhere because my car wont start , thanks chris
Old Apr 27, 2006 | 08:02 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
what condition is the car? stock? stock motor and intake? stock fuel line location? headers or exhaust manifolds?
Old Apr 27, 2006 | 10:39 PM
havoxe30's Avatar
Car: 88 GTA
Engine: l98 Modded
ya no , its far from stock it is all bolt on though it has edelbrock headers, ported plenum and runners, fuel press regulator, hypertec chip, 3" catback and tranny work and a bunch of other stuff that wouldnt have anything to do with the prob , i just got done taking it for a ride since its late and cool outside i didnt smash on it just cruzin around and she was fine took her home and she restarted fine , its only when im beatin on her alittle and its hot outside when it happens
Old Apr 27, 2006 | 10:42 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
boiling gas= vapor lock, that syour problem right there
Old Apr 27, 2006 | 10:55 PM
havoxe30's Avatar
Car: 88 GTA
Engine: l98 Modded
Thats what i thought, but how do i cool the gas down .Is there some cheap fix that i dont know about and has anyone had this prob before. Also is there a for sure way i can check to make sure thats is.
Old Apr 27, 2006 | 11:11 PM
its usually caused by a poorly designed fuel delivery system with which these cars had brand new from the factory. Check if your fuel pump is struggling to deliver the fuel, you could also install a return style FPR to help with keeping the fuel cool...its just basically diagnosing your fuel system and make upgrades/improvements where necessary, thats the only way to fight vapor lock.
Old Apr 27, 2006 | 11:22 PM
havoxe30's Avatar
Car: 88 GTA
Engine: l98 Modded
thanks alot man im gona go through everything tomarrow and see if i cant narrow down something but thanks again, chris
Old Apr 28, 2006 | 02:22 PM
Pearl91GTA's Avatar
Car: Trans Am GTA
Engine: 5.7L TPI
Transmission: TH-350
Axle/Gears: 3:23
its the starter selenoid. It gets to hot then wont send signal to the starter and start the motor. im in the process installing a mustang remote mount selenoid..
Old Apr 29, 2006 | 09:22 AM
Pearl91GTA's Avatar
Car: Trans Am GTA
Engine: 5.7L TPI
Axle/Gears: 3:23
go to the electronics forum
Old Apr 29, 2006 | 09:50 AM
'86 350's Avatar
Car: '86 Camaro SC
It its most likely vapro lock like others have mentioned, although it could also be the starter getting heat soaked. But that wouldn't last 2 hous or so, I'd bet on vapor lock.
Old Apr 29, 2006 | 10:23 AM
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
header wrap isnt a bad idea. It made a big difference for me.
Old Apr 29, 2006 | 11:02 AM
nedoss's Avatar
Car: 1986 Camaro
Engine: 355 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 4:11 posi
Hard restart
Ditto, I would wrap either the exhaust where it gets close to the fuel lines or wrap the fuel lines themselves with header wrap or a makeshift heat shield (aluminum or sheet metal, cheap and easy to bend).
One other option is to raise fuel pressure, because for you physics majors out there when you increase the pressure you increase the point at which the liquid boils. Just a thought.
Old Apr 29, 2006 | 06:00 PM
havoxe30's Avatar
Car: 88 GTA
Engine: l98 Modded
Is not the starter because it cranks fine it will crank untill my car dies , but most likely its the vapor lock. I noticed there was tons of pressure in the tank when i drive it for a while so i did the whole drilling 1/8 hole in the cap, and i got under the car and checked the vent valve. It had stuff cramed in it so i blew it out and it works good now , but so far ive driven it twice in the afternoon it was about *80 outside i smashed alittle to see if it would still start, and its started every time since i drilled those holes. So i dont know maybe that fixed it or maybe something else but im going to buy some of that heat wrap today anyways to help cool down the fuel
Old Apr 29, 2006 | 08:09 PM
Steve89GTA's Avatar
Ignition Coil. I had the same prob and dats what it was
Old May 2, 2006 | 08:00 PM
havoxe30's Avatar
Car: 88 GTA
Engine: l98 Modded
hey guys so ya i have been driving the TA for a couple days now and it just did it to me again took it home shut it off wouldnt restart so i checked the spark and it would spark for 2 sec then would stop so i said its gota be the coil because that is the only thing that is old so i went and bought one put it in started up fine drove it around again parked it wouldnt restart , i dont know what the hell the prob could be , could it be the esc moldule thing its new but could it have gone out
Old May 3, 2006 | 01:36 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Have it tested.
Old Jun 6, 2006 | 01:44 AM
Orizon's Avatar
Car: 1984 Trans Am
Engine: BuiLt 350! Hooker 2055's
Transmission: T5-manual trans-centerforce clutch
mine was doing that to me and it was the icm
Old Jun 6, 2006 | 12:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You really need more data during the times that it won't start. Do you have spark at the plugs? What is your fuel pressure? Are your injectors firing?
Vapor lock with a pusher electric pump system is extremely unlikely. By definition.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
Ranbo108
Sep 9, 2015 12:20 PM
TheExaminer
Sep 6, 2015 11:40 PM
Bryan F
Aug 18, 2015 02:28 PM
