Pro Topline Heads Question
Old Apr 28, 2006 | 12:22 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
I have a 74 corvette 350 with a hydraulic cam. I have a pair of these Pro Topline heads http://www.protopline.com/2236494906.asp
I bolted on one of the heads, then started to bolt on the rocker arms. At this point, we noticed that the pushrods were too short, probably by about 1/2". So first I called the guy I got the heads from, and asked him what length pushrods to use. He told me to use the 7.8" pushrods, which is what I have. After a bit of research, I realized the heads are designed for a newer motor with a roller cam and lifters. My first thought was to just use longer pushrods, but I wanted to make sure there weren't any other problems. Does anyone know whether or not I can use these heads with my motor? If so, is it just a matter of longer pushrods, or is there more to it?
Old Apr 28, 2006 | 02:58 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
You should be able to use standard length pushrods with the heads. I believe the roller lifters are a bit taller than flat tappet ones. 96 + vehicles would have roller lifters which could be why those were recommended. I'm not 100% sure on this, so hopefully someone can confirm.
Old Apr 28, 2006 | 03:31 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Those are the Vortec replacement heads. As far as bolting to the block, there is no difference. As far as the differences between heads used with roller cams versus flat tappets, there really are none. The only differences are the pushrod lenght (which has no effect on the heads being designed for one engine or another) and the method used to center the rocker tip to the valve.
You will need a new intake with those heads.
By the way, pushrod length checking tools do exist.
Old Apr 28, 2006 | 04:24 PM
Diabolical's Avatar
Engine: 305HO L69
I was my original thought to just use longer pushrods, but I wasn't sure if there were any internal changes like the reverse flow cooling on ls1 motors. I bought a pushrod checker, but I just wanted to make sure that the pushrod length is the only problem that I would run into. When I purchased the heads, I also bought an intake to match. Thanks for your help.
Old Apr 28, 2006 | 04:38 PM
1991project's Avatar
Car: 1991 Z28
Engine: 408 LSX
Transmission: Pro-shifted T-56
Axle/Gears: 9"
be sure and check for clearance issues where the pushrod goes through the head if you swap to a bigger diameter.....btw what length did you come up with...just curious
Old Apr 28, 2006 | 04:58 PM
Diabolical's Avatar
Engine: 305HO L69
what diameter pushrods should i use? i honestly won't get a chance to check the length for another week or two. i'll let you know when i find out.
Reddeath210
Oct 6, 2015 08:20 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
