temp sensor on heads
Old Apr 30, 2006 | 11:53 PM
82_t/a_305's Avatar
Car: 1982 Trans Am
Engine: 305 H.0
Transmission: th350
i just put a new set of heads on my car and i have to hook up the temperature sensor but i cant get the plug off , is there any way of relocating the sensor??
Old Apr 30, 2006 | 11:58 PM
z28camaroracer's Avatar
Car: 84 Z28, 89 RS, 98 SS
Engine: 350 .060 over, 350 .040 over, LS1
Transmission: TH350, TH700r4, T56
Axle/Gears: 4.11 spool, 3.73 open, 3.42 posi
you may be able to relocate it to the intake manifold on the front crossover depending on your intake.
Old May 1, 2006 | 12:10 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Depending on the intake you may have a couple of spots on the crossover to use.
You could also put in in the water neck if you still have the factory one with the 2 threaded holes. but it wouldnt be the best place to put it because when the thermosts goes your most likely not going to know it untill somethings on fire!
Old May 1, 2006 | 03:54 PM
82_t/a_305's Avatar
Car: 1982 Trans Am
Engine: 305 H.0
Transmission: th350
i have an edelbrock performer EPS intake
Old May 1, 2006 | 07:04 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
It will have 2 holes in the front coolant passage then.
Go pick yourself up an adapter and you should be ready to roll.
Old May 1, 2006 | 11:44 PM
82_t/a_305's Avatar
Car: 1982 Trans Am
Engine: 305 H.0
Transmission: th350
what kind of adapter , is it availible at any part store ?
Old May 2, 2006 | 12:54 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Available pretty much anywhere.
to put it correctly its a bushing your looking for. i cant remember the size off the top of my head but its something like 1/2"NPTx1/4"NPT that your looking for.
Just pull one of the plugs out of the intake and bring that and the sending unit down to the store with you. that way theirs no running back and forth.
Old May 2, 2006 | 09:08 PM
82_t/a_305's Avatar
Car: 1982 Trans Am
Engine: 305 H.0
Transmission: th350
ok i got the adapter now i got it fixed thanks for the help
italiano67
Dec 11, 2016 09:21 AM
bamaboy0323
Sep 3, 2015 06:07 AM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
