running rough
Old May 1, 2006 | 04:53 PM
immortal's Avatar
running rough
I hope I dont get booted off for this being a question about a 95 camaro, but I used to have a 85 and 91 camaro and you guys were so helpful.
I got a 95 now, its a 3.4 6cyl. a couple of months ago the car started shaking a little at stop lights hardly noticiable. Now the car shakes alot noticibly and it sputters away as I increase the gas. the car does it after the car is warmed up. Also when I try to give it alot of gas it kind of hesitates. The weird thing is it started doing it intermittely and now its doing it all the time (including cold but not that bad). I cleaned the IAC and the check engine light isnt coming on. I tryed to pull the codes but the ALDL has 16 connectors its an 0bd 1 but the connector was for OBd2 (I read GM put the OBD 2 connector eventhough its not). I changed the plugs,oxygen sensors, catalytic convertor, fuel filter and checked the wires and for visible vacuum leaks. Any one know if you can pull the codes on this car without a scanner?
p.s. i posted in the v6 forum but the replies arent pourning in
Old May 1, 2006 | 07:03 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I think Advance or Autozone can pull codes for you for free - now whether or not you get a person that knows what they are doing, and can get the info for the codes correct, is another matter.
Old May 1, 2006 | 09:56 PM
immortal's Avatar
I went to autozone and they said by state law there not allowed to check the codes but they lent me the scanner (they said autozone only has obd II scanners) and my car has the obd ii aldl but its a obd I set up. I read somewhere that the 95 camaro was the year that this happened. So when I tryed to use the obd ii it said linking error and would not work.
Old May 1, 2006 | 10:24 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Well if its OBDI just jump the pins then...
Old May 2, 2006 | 01:06 AM
immortal's Avatar
i tryed every possible alternativein the aldl to jumping the codes and nothing makes the check engine light blink. is there something i'm missing,
customblackbird
Aug 15, 2021 10:16 PM
jbd1969
Aug 17, 2015 07:06 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
