How long should a TPI system hold Fuel Pressure after car is shut off?
Old May 1, 2006 | 11:50 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Engine: Rebuilt Vortec Headded 358SB 9.5:1
Transmission: 700r4, corvette servo, Transgo kit
Axle/Gears: 3.23 POSI
Asking for exactaly what the title says- Thanks!
Old May 2, 2006 | 12:57 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
in a perfect world it would hold it indefinately...
Old May 2, 2006 | 01:37 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i don't think so. the fpr is just a pinched off line basically and fuel will bleed through it. i think after shutdown it should hold for a second but slowly and steadily drain down.
Old May 2, 2006 | 06:03 AM
In the real world, any MPFI system, TPI included, should hold at least half of its pressure at least 6 or 8 hours; i.e. I'd want to see 20 psi minimum after 6 hours
Old May 2, 2006 | 10:11 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
now the main beef: why do you want to know? to solve a problem, or just out of sheer curiosity?
Old May 2, 2006 | 05:05 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Well, i was talking to a guy i talk to on Yahoo about my car, and we were trying to figure out why my car- with all the mods and in theory should be fast, is so damn slow.
we were talking about fuel pressure, changing the filter, and how long the TPI system should hold pressure and if a filter didnt give me more power that i should adj. the cam timing 4 deg adv. He said he thought a system should hold it overnight b/c his buddies mustang has a FP gauge on the hood- and i said- well the TPI is a return fuel system- so it would make sense that it bleeds through though after shut off..
well- i changed my fuel filter today and got 5 more psi of fuel pressure at idle, but it still bleeds out w/in like 20 sec. to like 8 psi after shut down. - so i was curious if its possible that the LT1 injectors i bougt off a guy on here are bad and leaky...
Ive not noticed any more power gain from the new fuel filter, however i adjusted my TV cable to all the way tight, and that seemed to make a difference, but my car still doesnt fry the tires like he said his stock tpi 350 does. and i was like- yeah, something is up. and he was like " yeah" and i said " in theory- my engine should be making 300 hp and should smoke anything i see daily" and he said " yeah in theory" and i said "yes, but im not dealing w/ theory, im dealing w/ why have i put all this $ into this car and its still so ****ing slow"
anyone have any ideas? I've not adjusted the cam timing yet its set straight up at 0deg, and the Ignition timing is set at 6 deg adv.
all mods listed in side bar and signature
Thanks!
Jeff
Old May 2, 2006 | 06:14 PM
Sonix's Avatar
Car: 1982 Trans-Am
more than...? what is your typical fuel pressure?
could be bad injectors. you're thinking of getting the car dyno'd, why not do that and find out where in the power band it's making power, and where it's not?
kind of a tame cam though...
Old May 2, 2006 | 06:15 PM
joe350's Avatar
Car: 91 Z28
Engine: 350 TPI (L98)
Fuel pressure will bleed off unnoticably slow. If you are down to 8 PSI in 20 seconds then you definately have a leak somewhere.
Old May 2, 2006 | 06:23 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
it was like 45 on startup and 35 on idle, today it got 45 startup and 40psi idle..
well, its not really 8.. its like 12.. but still
Old May 2, 2006 | 07:47 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Just FYI i hope you didnt actually pull the TV cable tight...
It HAS to be adjusted properly, if not you will loose your tranny in a real hurry!
Its not like the older TH350/400's which have a detent cable to initiate kickdowns, The 700R4 uses the TV cable to know what the throttle position is at and whats going on because it has not vac modulator!
Old May 2, 2006 | 08:17 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
well, it seems to shift like it's supposed to.. before the shifts were sloppy and weak, now they are firm and seem like it shifts the way Transgo said it should
Old May 2, 2006 | 08:40 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
I am kinda thinking that my injectors are kinda leaky.. i bought them off a guy here on TGO they are LT1 injectors.. but i dunno how old they are or anything, i know the car runs and fires on all cyl's but i think a couple may leak. and the car also backfires when i come out of being on the throttle hard.. ( ive only got a y pipe, 90 deg. bend and a muffler under the driveshaft tunnel until 2morrow when the rest of the exh. gets finished)
but a guy said that it could be backfiring b/c the injector is leaking and still feeding fuel through..???
thanks for any help guys!
Old May 3, 2006 | 12:24 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
can u pull the injectors from the intake manifold but leave them in the rail, that way you turn on ignition. let the pump prime and see if any of those injectors are trickling any fuel?
Old May 3, 2006 | 01:10 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
pull the injectors from the intake and turn on the ignition to see if any leak out, if so you know your problem.
Old May 3, 2006 | 01:12 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i just said that :P
Old May 3, 2006 | 01:24 AM
xpndbl3's Avatar
Car: 1984 Z28
where should i mail your cookie to? for being quicker on the draw.
Old May 3, 2006 | 01:38 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
don't sweat it. I'll pretend my next cookie came from you.
Old May 3, 2006 | 01:14 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
OK- i may try this..- Also- we figured out last night that im running a 88 Hypertech memcal w/ a zif and a prom burned for the ARAP bin from Tunerpro.net and im using an 86 auto computer- would this make a difference in power and timing and fuel???
Old May 3, 2006 | 02:43 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
yup
Old May 3, 2006 | 04:36 PM
joe350's Avatar
Car: 91 Z28
Yeah, but not a difference in fuel pressure.
Old May 3, 2006 | 04:45 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Well- the good thing is that - I've got about the right amount of fuel pressure..
what im trying to figure out here is why for all my mods- the car doesnt have the low end power it seems like it should.. and the whole thing about how long the fuel pressure should hold was just a question to see if i may have a leak...and i indeed think i might. but there are still other things to figure out- such as getting those computer spec's straightedned out.. I guess i need to get a MOATES adapter...
Anyone got anything else for me to try??
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
Kaweh
Aug 9, 2015 02:54 PM
