how do u change lifter
Old May 2, 2006 | 05:13 PM
xnick115x's Avatar
i have a 3rd gen camaro iroc z and i want to change the lifters does anyone know how to do it
Old May 2, 2006 | 06:09 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
remove your carb/fi, and intake manifold. remove your valve covers, back off your rocker arm nuts, remove your pushrods. try using a magnet to lift up the lifter, and pull it out. Or grab it with pliers and yank. soak new ones in oil, moly lube on the bottom.
reset lash and install parts. use break in procedure as if you put in a new cam (good time to do that if you want to )
why do you want to replace them? They don't generally "fail" out of nowhere, and are the only thing you have to replace to be good as new, sorta thing.
Old May 2, 2006 | 10:43 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
And many times when they fail, there is something else to worry about as well, particularly with flat tappet ones.
db057
Sep 4, 2015 07:57 AM
Mickeyruder
Sep 2, 2015 02:45 PM
Brendankup
Aug 30, 2015 01:46 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Cameeeero
Aug 20, 2015 03:06 AM
