runnin rough!!!!
runnin rough!!!!
i have a 88 trans am gta 350ci tpi with about 104,000. the vehicle will jerk as im tryin to accelerate on a highway and has no power and at stop lights the car will jerk as well, the rpm will jump up and down as well as in idle. i have changed, plugs, wires, cap, rotor, fuel filter, air filter less than a year ago. and just had checked for visible vacuum leaks and timing. still cant find the problem. would greatly appreciate some help on this. thanks
are you getting any power when you get on it or not at all really just putting along
cause i am having the same problem and i took it to shops and the ran digansitcs it might be your mass air flow sensor or i was told it can also be you catalitic convertor.
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Even just the MAF burnoff relay does this . Causes surgeing . Try that befreo buying a MAF . Also try and tap it lightly to see if the condition changes. Try unplugging it to see if there are changes
good luck man !
good luck man !
