Starter shim to make it extend further out
Old Apr 8, 2006 | 08:23 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I saw a thread here a while back about a shim kit to cause the gear on the starter to extend further out when activated. Right now the gear and the flexplate mesh perfectly, however only the tip of the gear meets the flexplate. To be clear: I'm not talking about the thin shims between the starter and block. Does anyone know what I mean or know who posted the thread? Search turned up 150+ threads.
Old Apr 10, 2006 | 12:16 AM
Vader's Avatar
Starter shims on Chevy engines are to space the starter father below the centerline of the flywheel, which also causes more tooth clearance.
If your starter gear does not engage deeply enough, check the yoke between the solenoid and the bendix, and the pivot pin for it. Those are common areas for wear and bending. Many times the two pins that engage the bendix are worn flat, and the yoke can be removed, turned over, and reinstalled.
Old May 6, 2006 | 06:24 PM
Car: 86 T/A
Engine: HSR 355
Thanks I'll check those areas. The thing is that I saw a thread on here recently of someone getting a rebuild/shim kit that actually caused it to extend further. I'm tossing my fullsize starter on there for now though.
Frozer!!!
Jan 19, 2024 04:55 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Linson
Aug 21, 2015 02:12 PM
milk
Aug 10, 2015 06:26 PM
