I was stuck on the side of the highway!!
Old May 6, 2006 | 12:39 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Hey everyone,
I need your help. I had the cruise control set at 65 and all of a sudden the car lost some power. At first I thought it was a bad alternator cause the voltmeter was a little lower then usual and the loss of power was similar to the time my alternator did take a dump on me, but the headlights were still bright. Within 5 seconds the engine "backfired" twice quickly and stalled out while I was doin 65. I got the car pulled over onto the shoulder and called a few local TGO buddies. I check for fuel, injectors were clicking and fuel was spraying. I then pulled the drivers side front plug, inserted a screw driver and checked for spark. Nothing, So I pulled the wire comimg off the coil and no spark there either. I checked the connections to the coil and the dist. Nothing. I replaced the coil in January with an Accel coil. Is it possible that the coil went bad already? I plan on buying a standard coil tomorrow and seeing if that works. I had a buddy called AAA and had the car towed to his apartment. I have to leave it there and after work tomorrow I'll get a ride and try to get it running. If it does run I'll order a MSD and return the standard coil when the MSD arrives. If it doesn't work what should I check/do next?
Old May 6, 2006 | 01:12 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I had a MSD blaster coil die on me in 30 miles on my daily driver. Then once again, I had no spark from the coil, but the coil was fine. This time the ignition control module went bad.
Old May 6, 2006 | 01:20 AM
krisb410's Avatar
How do you test to see which part is bad?
Old May 6, 2006 | 01:25 AM
Car: 1988 IROC-Z
Engine: 427 SBC
I took the coil out of my camaro and put it in my daily driver, and there was still no spark. So then I replaced the ICM.
Old May 6, 2006 | 11:05 AM
krisb410's Avatar
Ok, I'm at work now (Chevy Dealership) and got a new Coil, ICM, and pickup coil to take with me to the car. I can return the parts that I don't install, so what should I check 1st and how do I check?
Old May 6, 2006 | 11:09 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
the one time my car left me stranded... the rotor had poped off in the distributor, and it took the coil with it. They parts guy had given me toe wrong part. replaced the rotor, cap and coil, and I was good to go. I'm not saying thats what happened to you, just pull the cap and have a look.
Old May 7, 2006 | 04:07 PM
krisb410's Avatar
Well, turned out to be the ICM.
Vintageracer
Jan 10, 2020 05:33 PM
Cameeeero
Sep 18, 2015 04:00 PM
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
