VSS help, engine swap to TPI
Old May 7, 2006 | 07:18 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
So I have an 89 RS L03, and am currentlyin the process of pulling the old motor and installing a 350 tpi setup that is speed density. I bought a VSS sensor that is supposed to connect to the transmission tail. The cable goes to the sensor and he sensor goes in the tail. But, does a factory harness have such a connector to send signal the ECM???
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
