left hand right hand dipstick
Old May 7, 2006 | 03:05 PM
surfertom's Avatar
Car: 86 Z-28
Transmission: 700-r4
what kind of troubles will i encounter installing a left side oil dipstick 350 block as opposed to the right side which of course my car came with. tom
Old May 7, 2006 | 04:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's not that big a deal. You can abuse the dipstick tube into place, or you can get a flexible aftermarket replacement one, like the one from Lokar.
Old May 7, 2006 | 04:17 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
The dipstick itself is going to be your only difference between the 2 motors. And like ape said you can either motivate the dipstick into place or buy a replacement either made to fit the specific L/R side or a flex one.
Old Apr 7, 2011 | 02:06 PM
ScudBud's Avatar
Re: left hand right hand dipstick
ok, what if I have the same as original post, but my original block was one piece seal, would a 2 piece seal work?
Old Apr 7, 2011 | 02:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes
Old Apr 7, 2011 | 03:12 PM
ScudBud's Avatar
so it also looks like I have a large crankshaft journal, and this block I just bought is designed for a small journal... Do I just buy a new crankshaft with a small journal, or am I screwed and need to sell the block I just bought and buy a block designed for a large journal?
Old Apr 7, 2011 | 03:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What block did you get?
Old Apr 7, 2011 | 03:47 PM
ScudBud's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT
Old Apr 7, 2011 | 03:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's not a small journal block.
Old Apr 7, 2011 | 04:15 PM
ScudBud's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
here is one I think I have. if you look at the second picture from the top the very bottom piece, that seems more like the piece I have. I will make a youtube video real quick for you. Thanks so much for helping me.
Old Apr 7, 2011 | 04:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A 1 piece RMS block is definitely not a small-journal block.
Old Apr 7, 2011 | 04:25 PM
ScudBud's Avatar
http://www.youtube.com/watch?v=bBbwfeA0kd8
Old Apr 7, 2011 | 04:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's the difference in 1 piece and 2 piece rear main seals... nothing at all to do with journal size. (Except of course that there are no different journal sizes in 1 piece RMS blocks.)
Old Apr 7, 2011 | 04:52 PM
ScudBud's Avatar
so then I need to buy a one piece main seal crank shaft?
Old Apr 7, 2011 | 04:59 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
For a one-piece block, yes.
Old Apr 7, 2011 | 05:20 PM
ScudBud's Avatar
so then the shaft is all I need to buy then? the heads will fit and pistons and everything else?
Old Apr 7, 2011 | 05:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The heads will fit any block. Pistons will fit if you use the same bore, stroke and rod length.
Old Apr 7, 2011 | 05:30 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Need a 1 pce seal oil pan if you don't already have it
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
KCG
Sep 23, 2015 09:05 AM
ericjon262
Sep 11, 2015 06:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
